Refer to the document/application in an add-in?
1162
05-08-2013 09:04 AM
JoeMcCollum
Is it possible to refer to the Application/document in an add-in?
I've successfully attached a dockable window to a button - now what do I do?
It doesn't seem to like:
Dim pMxDoc As IMxDocument = new MxDocument
nor can you do:
Dim pMxDoc As IMxDocument = m_application.Document
or maybe you can but how do you set m_application in a dockable window?
ANSWER: Add the lines in bold
Private m_pApp As ESRI.ArcGIS.Framework.IApplication
Public Sub New(ByVal hook As Object)
' This call is required by the Windows Form Designer.
InitializeComponent()
' Add any initialization after the InitializeComponent() call.
Me.Hook = hook
m_pApp = hook
End Sub
then down in your button_click do:
Dim pMxDocument As IMxDocument = m_pApp.Document
Thanks!
RichardWatson
var applicationObjectType = Type.GetTypeFromCLSID(typeof(AppRefClass).GUID);
                        var rawApplicationObject = Activator.CreateInstance(applicationObjectType);
                        _application = (IApplication)rawApplicationObject;
TerryGiles
Since you're working with an Add-In you can also just reference the internal ArcMap class & it's Document member which returns IMxDocument -
IMxDocument mxdoc = ArcMap.Document;
