really slow retrieving list of featureclasses from sde
1036
09-22-2011 03:22 PM
DerekLoi
my code works fine but returning a list of sde featureclasses takes quite a while
shouldn't it be quick?  my old MapObjects code to list SDE featureclasses in a listview just took less than 5 seconds...
can anyone help?  this issue is pretty annoying! :mad:
here's my code:
            ESRI.ArcGIS.Geodatabase.IEnumDataset enumDataset = workspace.get_Datasets(esriDatasetType.esriDTFeatureClass);
            enumDataset.Reset();
            lblStatus.Text = "Retrieving SDE featureclasses.  Please wait...";
            ESRI.ArcGIS.Geodatabase.IDataset dataset = enumDataset.Next();
            while (dataset != null)
                //this will list the name of the featureclass in the root of the sde server
                //myFeatureclassList.Items.Add(dataset.BrowseName);
                if (dataset.BrowseName.ToString().IndexOf("Tract_" + DateTime.Now.Year.ToString()) >= 0)
                    lblStatus.Text = "Adding featureclass: " + dataset.BrowseName;
                    //have to use a delegate or in this case INVOKE to prevent the cross-thread error
                    this.Invoke((Action)(() => myFeatureclassList.Items.Add(dataset.BrowseName)));
            lblStatus.Text = "Sorting contents...please wait...";
            this.Invoke((Action)(() => list_featureclass.Sorted = true));
DerekLoi
here's my code:
ah ha...  i guess the best way to achieve this is to just query the sde server from sql...
and it only takes like 1 second to return all the featureclasses and all the versions!!!
