Problems with java add-ins
4575
17
05-23-2012 05:10 AM
AlbertoDe_Luca
Hello everyone.
Since ArcGIS 10 supports java for desktop development too, I tried to set up a java add-in for ArcMap. Before writing my own add-in I had a go with one of the samples provided by the Java SDK, called "simpleaddin".
I can add the add-in to ArcMap without problems, and I can see it listed in the Add-In Manager.
Unfortunately, when I bring up the add-in toolbar (SampleJava Toolbar) in ArcMap, no custom commands are shown, just a bunch of labels saying "missing". Native ArcMap commands (like Fixed Zoom Out) are visible on the toolbar though (see attached image).
I also tried to create my own add-in, following the instructions given in this video:
http://resources.arcgis.com/gallery/video/java/details?entryID=F8A0A38E-1422-2418-7FA3-CC2C83ED9674
but in this case I couldn't even find my custom command in the commands list under "Customize".
I tried on two boxes, both running win7/64 and ArcMap w/ the most recent SP available installed.
Any clues?
Thanks a bunch
Alberto
LeoDonahue
Occasional Contributor III
I don't think the sample Java Add-ins work right, as that is how the toolbar appears when I run it.
Normally, Java Add-ins deploy to a Command Category called "Java Commands", unless you created a toolbar and added those commands to the toolbar.
Have you read through this tutorial?
http://help.arcgis.com/en/sdk/10.0/java_ao_adf/conceptualhelp/engine/0001/0001000003m3000000.htm
Also, if you are developing under 10.0 on Windows 7, you can't use a 64-bit jvm, you still have to use the 32-bit jvm.
AlbertoDe_Luca
Thank you ldonahue for your reply.
I went through that tutorial, and created a simple add-in with just one button popping up a message. The add-in installed ok (I got the "Installation succeeded" message, and the add-in is listed in the Add-in manager), but when I go to the Commands list to add the button to an existing toolbar, the "Java Commands" category (where the button is supposed to be) isn't even there.
I then checked my system's default JRE version, which actually was 64 bit. I removed it from the system, so now the default version is the 32 bit 1.7.0_02, but my problems are still here...
Any other suggestion?
Alberto
LeoDonahue
What values did you give for the button's required fields in the attached screenshot?
In this example, you 'should' find a button called Test Button in the 'Java Commands' category.  Or if you named your category something other than 'Java Commands', then look in that category name for your button.
AlbertoDe_Luca
ldonahue,
the values are "New Button 1" and "Java Commands" (these are the names listed in the Add-In manager too). Nevertheless, the category "Java Commands" doesn't even exists in the Commands list.
What configuration do you have? Is your system 32 or 64 bit? I feel like I'm missing something big here, because from the tutorials setting up a java arcmap add-in seems like a piece of cake... Maybe my service pack version is bugged (AG10 w/ sp4)? Maybe special privileges are needed?
Alberto
LeoDonahue
I'm using:
Eclipse Indigo 3.7.1
Java 1.6.0_29 32-bit SDK
ArcGIS Desktop 10.0 SP4
Windows 7 SP1
If you have ArcMap open, remove your add-in using the add-in manager, close ArcMap, and re-export your add-in.  Launch ArcMap again, do you see your command now?
Are you creating an add-in for ArcMap?
AlbertoDe_Luca
Ok,
you've got my same setup (i've got win7/64 though).
I did what you advised:
- removed my add-in from add-in manager
- re-exported the add-in from eclipse (yes, it's an arc-map add-in)
- re-added add-in to arcmap (see attached screen cap, left)
- command still not available on command list (see screen cap, right)
[ATTACH=CONFIG]14687[/ATTACH]
D'oh!
Alberto
DorisRiedl
I had a similar problem last week. My AddIn category did not appear. It was a blank at the end of the category name, that caused this problem.
AlbertoDe_Luca
Thank you dorisriedl,
I've checked and made sure there were no blanks in my command and category names. I also removed the space between "Java" and "Commands". No luck.
Alberto
LeoDonahue
Alberto,
Can you post a screenshot of your config.xml as seen in Eclipse?
