When I installed, it has installed successfully. But Iam not able see the tool neither in ArcMap nor in ArcCatalog nor in Add Remove Programs. What could be the problem?
Did you verify that it registered? Here's a blurb from the help that explains where to verify:
The XML database generated by ESRIRegAsm.exe has a .ecfg file extension. It is a zipped XML file that can be unzipped and read. For ArcGIS Desktop 10, the .ecfg file is located at, ~:\Program Files\Common Files\ArcGIS\Desktop10.0\Configuration\CATID. For ArcGIS Engine 10, the .ecfg file is located at, ~:\Program Files\Common Files\ArcGIS\Engine10.0\Configuration\CATID.
