Polygon Buffer - How to set  FLAT corner paramater
2729
7
01-23-2012 12:06 AM
Durga_PrasadD
How do I modify the code below to get the Buffer polygon with FLAT corners
Sub MyCreatePolygonBuffer()
    Dim pMap As IMap
   Dim pMxDoc As IMxDocument
   Dim pFeatureClass As IFeatureClass
   Dim pFeatureLayer As IFeatureLayer
   Dim pFeatureCursor As IFeatureCursor
   Dim pOutFeatureCursor As IFeatureCursor
   Dim pfeature As IFeature
   'Split lines for selected layer
   Set pMxDoc = ThisDocument
   If Not pMxDoc.SelectedLayer Is Nothing Then
     Set pFeatureLayer = pMxDoc.SelectedLayer
   Else
      MsgBox "Please select a polygon layer to buffer"
      Exit Sub
   End If
    Dim pLayerInnerPolygon As IFeatureLayer
    Dim pLayerOuterPolygon As IFeatureLayer
    Set pMap = pMxDoc.FocusMap
    Set pLayerInnerPolygon = pMap.Layer(0)
   Set pFeatureClass = pLayerInnerPolygon.featureClass
   Set pFeatureCursor = pFeatureClass.Update(Nothing, False)
   Set pfeature = pFeatureCursor.NextFeature
   Dim pBufferConstruction  As IBufferConstruction
   Set pBufferConstruction = New BufferConstruction
   Dim pBufferPolygon As IPolygon
   Set pBufferPolygon = New polygon
  'How to make use of this property ?
   'Dim pBufferConstructionProperties As IBufferConstructionProperties
  ' pBufferConstructionProperties.EndOption = esriBufferFlat
   Do Until pfeature Is Nothing
            Dim pPolygon As IPolygon
            Set pPolygon = pfeature.Shape
            Set pBufferPolygon = pBufferConstruction.Buffer(pPolygon, 10)
  Loop
 AddPolygonToGraphicsLayer pBufferPolygon
End Sub
sapnas
According to IBufferConstructionProperties documentation, ConstructBuffers and ConstructBuffersByDistances  methods make use of these properties whereas Buffer method does not.
Durga_PrasadD
Would you share an example to accomplish that.
sapnas
I have never used these properties. But you could try adding input geometry to geometrycollection and use it with constructbuffer method.
IGeometryCollection pInGeomColl = new GeometryBagClass();
                    object Missing = Type.Missing;
                    pInGeomColl.AddGeometry(pfeature.Shape, ref Missing, ref Missing);
 IGeometryCollection pOutGeomColl = new GeometryBagClass(); ;
                    IBufferConstruction pBufferConstruction = new BufferConstruction();
                    IBufferConstructionProperties pBufferConstructionProperties =
                        pBufferConstruction as IBufferConstructionProperties;
                    pBufferConstructionProperties.EndOption = esriBufferConstructionEndEnum.esriBufferFlat;
                    pBufferConstruction.ConstructBuffers(pInGeomColl as IEnumGeometry,10,pOutGeomColl);
Durga_PrasadD
I have modified my code as below.I still get the rounded corners.:(
Dim pInGeomColl As IGeometryCollection
Set pInGeomColl = New GeometryBag
pInGeomColl.AddGeometry pfeature.Shape   'Adding my polygon to geom collection
Dim pOutGeomColl As IGeometryCollection
Set pOutGeomColl = New GeometryBag
pBufferConstruction.ConstructBuffers pInGeomColl, 40, pOutGeomColl
Set pBufferPolygon = pOutGeomColl.geometry(0)
sapnas
BTW Buffer tool never generates a sharp cornered polygon since the outer polygon is 'd' distance from the vertex of the inner polygon in two different direction. From mathematical perspective it is accurate. If you want sharp corners, You may have to edit the resulting buffered polygon and remove the arc and increase the length of the lines to change it to a sharp cornerred polygon.
nazerehnejatbakhsh
Hello there,
could you ever solve this problem !? I am confronting the same issue !
Thank you very much,
Nazereh
Govindrao
Hi
Try this may work in ARCGIS 10 but its not working in 10.1.I want to know the reason
            'pPolygon = pfeature.Shape
            Dim ptop As ITopologicalOperator
            ptop = pfeature.Shape
            Dim pPl As IPolyline = New Polyline
            pPl = ptop.Boundary
            Dim pConstructCurve As IConstructCurve3
            Dim test As Double
            test = 3.048
            pConstructCurve = New Polyline
            pConstructCurve.ConstructOffset(pPl, -1 * test, esriConstructOffsetEnum.esriConstructOffsetMitered + esriConstructOffsetEnum.esriConstructOffsetSimple)
            ConstructOffset = pConstructCurve
            'pBufferPolygon = ptop.Buffer(-20)
            ' pBufferPolygon = pBufferConstruction.Buffer(pPolygon, 40)
            AddPolygonToGraphicsLayer(ConstructOffset)
        Loop
Govind
