Parallel Polylines with VBA
1673
5
09-23-2010 11:51 AM
LawrenceHughes
Hi
I have a VBA routine, where the user clicks on a polyline and the coordinates are returned. X1, Y1, X2 and Y2. I also have a routine to draw a line between these coordinates. How do I draw the polyline parallel to the original line, which is offset by the same distance, regardless of the zoom factor?
Thanks in advance.
Lawrence
NeilClemmons
Honored Contributor
Use IConstructCurve.ConstructOffset.
LawrenceHughes
Hi Neil
After a lot of surfing around, I found the following example:
______________
Private Function ConstructOffset(pInPolyline As IPolyline, dOffset As Double) As IPolyline
Dim pConstructCurve As IConstructCurve
On Error GoTo ErrorHandler
If pInPolyline Is Nothing Or pInPolyline.IsEmpty Then Exit Function
Set pConstructCurve = New Polyline
pConstructCurve.ConstructOffset pInPolyline, dOffset, esriConstructOffsetRounded + esriConstructOffsetSimple
Set ConstructOffset = pConstructCurve
Exit Function
ErrorHandler:
Set ConstructOffset = Nothing
End Function
______________
Here is my line drawing function. I can't get my function to correctly call the above function. Can you see what is wrong?
Many thanks
______________
Private Function DrawLine(x1, y1, x2, y2, aView As IActiveView, pMap, LineName)
On Error GoTo err_handler
Dim pPointCollection As IPointCollection
Dim pFromPoint As ipoint
Dim pToPoint As ipoint
Dim pPolyline As IPolyline
Set pFromPoint = New Point
Set pToPoint = New Point
Dim pLineSym As ISimpleLineSymbol
Dim pLineElement As ILineElement
pFromPoint.PutCoords x1, y1
pToPoint.PutCoords x2, y2
Set pPolyline = New Polyline
Set pPointCollection = New Polyline
Set oPointCollection = New Polyline
pPointCollection.AddPoint pFromPoint
pPointCollection.AddPoint pToPoint
Dim pGC As IGraphicsContainer
Set pGC = pMap
Dim pElement As IElement
Dim oElement As IElement
Dim oLineElement As ILineElement
Set pElement = New LineElement
Set oElement = New LineElement
pElement.Geometry = pPointCollection
Dim oLineSym As ISimpleLineSymbol
Dim SymCol As IRgbColor
Set pLineElement = pElement
Set oLineElement = oElement
Set pLineSym = New SimpleLineSymbol
pLineSym.Style = esriSLSSolid
pLineSym.Width = 3
Set SymCol = New RgbColor
SymCol.Blue = 255
pLineSym.Color = SymCol
pLineElement.Symbol = pLineSym
oLineElement = ConstructOffset(pPointCollection, 100)
Dim elemProps As IElementProperties
Set elemProps = pLineElement
elemProps.Name = LineName
pGC.AddElement pLineElement, 0
pGC.AddElement oLineElement, 0
aView.PartialRefresh esriViewGraphics, Nothing, Nothing
Exit Function
err_handler:
MsgBox Err & " - " & Error$
Resume
End Function
______________
NeilClemmons
Honored Contributor
Your ConstructOffset function returns a polyline.  You're trying to set a line element equal to that polyline.  That won't work as it is a type mismatch.  You need to set your element's geometry to be the polyline returned by the ConstructOffset function.
LawrenceHughes
Sorry Neil (or anyone else), my last reply should have read, how can I change my code to return a polyline and not an element? I am struggling with the concepts here.
Many thanks
LawrenceHughes
Hi
The above code is now working. What I really need is to create two parallel lines, which stay the same distance apart whether the user zooms in or out. Is this possible?
Regards
Lawrence
