Operation not allowed
1316
10-13-2019 05:14 AM
NadirHussain
Occasional Contributor II
i am writing a webapi.on my devlopment pc  the below code is working fine
Console.WriteLine("Ready with license.");
if (ESRI.ArcGIS.RuntimeManager.ActiveRuntime == null)
ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.EngineOrDesktop);
IPropertySet propertySet = new PropertySet();
propertySet.SetProperty("SERVER", "myServer");
propertySet.SetProperty("INSTANCE", "5151");
propertySet.SetProperty("DATABASE", "SDE");
propertySet.SetProperty("USER", "sa");
propertySet.SetProperty("PASSWORD", "ds");
propertySet.SetProperty("Authentication_mode", "DBMS");
propertySet.SetProperty("VERSION", "SDE.DEFAULT");
IWorkspaceFactory workspaceFactory = new ESRI.ArcGIS.DataSourcesGDB.SdeWorkspaceFactory();
workspace = workspaceFactory.Open(propertySet,0);
return workspace;
and i can perform all opations.
when i publish webapi in production server i am getting this error "operation not allowed."i debug the code
when program reached the above line.
It throws exception "Operation not allowed." i am stuck this line from last three days.I googled it.but could not find any answer.please help me.i will be very thanks full to all.pls pls pls help.
DuncanHornby
MVP Notable Contributor
Have you seen this page? The modern approach is to use Activator.CreateInstance to create the singleton object.
NadirHussain
Dear Duncan Hornby,
as per your suggestions i changed the line
IWorkspaceFactory workspaceFactory = new ESRI.ArcGIS.DataSourcesGDB.SdeWorkspaceFactory(); from this to
this line
IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance(factoryType);
and debug my program.My debugger pass the suggested line successfully and next line is the below line to open workspace
workspace = workspaceFactory.Open(propertySet, 0);
and on the above line it produces the same error "Operation not allowed."
the code works on development machine but not work on the deployment server.my deployment server operating system is windows server 2016 64 bit and development machine is windows 7 professional 64 bit os.
Please help.
Thanks and regards.
RonAnkeny
New Contributor III
I am in the midst of converting 10.2.1 code to run against our new 10.6.1 software and I have run into this exact same issue. Did you find the culprit?
NadirHussain
sorry for late reply.the below code is working with me on 10.6 and 10.7
private IWorkspace getWorkspace()
ESRI.ArcGIS.esriSystem.AoInitialize aoInit = null;
esriLicenseStatus licStatus;
IWorkspace workspace = null;
string status = "";
try
Console.WriteLine("Obtaining license");
aoInit = new ESRI.ArcGIS.esriSystem.AoInitialize();
licStatus = aoInit.Initialize(esriLicenseProductCode.esriLicenseProductCodeStandard);
if (licStatus == esriLicenseStatus.esriLicenseCheckedOut)
propertySet.SetProperty("SERVER", "IP");
propertySet.SetProperty("INSTANCE", "5151");------For  arcsde application server
propertySet.SetProperty("INSTANCE", "sde:sqlserver:sqlservername");------For  direct connect.
propertySet.SetProperty("DATABASE", "database");
propertySet.SetProperty("USER", "user");
propertySet.SetProperty("PASSWORD", "user");
Type factoryType = Type.GetTypeFromProgID("esriDataSourcesGDB.SdeWorkspaceFactory");
if (workspace != null) {
return workspace;
catch (Exception ex)
Console.WriteLine(ex.Message);
status = ex.Message.ToString()+" "+ex.Source;
return workspace;
ksoundaryasubramani
Tried the above Code Still in 10.6.1 I am facing  the same issue. Any other alternatives ?
