One application give me the coordinates and I have set the extent view as per those coordinates in ArcGis. Do you have idea?
4249
07-02-2015 09:46 PM
AnkurWalia
SachinKanaujia
You can try the following
pMxDoc.ActiveView.Extent = <your envelope from the coordinates that you get>;
pMxDoc
.ActiveView.Refresh(); // you can also use partial refresh
Other way if that you can get the current Scale and use center at of your envelope center or if you have a single point
axMapControl.CenterAt(<Point>);
axMapControl
.MapScale = <current MapScale>;
axMapControl
.Refresh();
SachinKanaujia
Can you please elaborate what exactly are you doing?
Do you know what is the Spatialreference of those coordinates? Can you give me what those coordinates look like?
I think you are asking that you have to set the extents in ArcGIS Desktop? Which product are you working on and what is the programming language/API you are using?
AnkurWalia
yes i have to set the extent view in Arcgis Desktop, The coordinates are in WGS84.
And i am using c#, Arcobjects.
SachinKanaujia
pMxDoc
axMapControl
axMapControl
.Refresh();
AnkurWalia
Thanks, Its working fine for me.
