New Map File Command with Java
1473
02-22-2011 09:52 AM
ViridianaGO
Hi! I have a question, how can I implement the New Map File Command whit Java in an application? Thanks.
TomSchuller
Could you describe deeper your idea?
Do you want a new menuitem in ArcMAP?
Or do you want to create a standalone ArcEngine application?
ViridianaGO
Thanks. I´m creating an application with ArcGis Engine using Java, I wanto to know how create a new map file like in ArcMap but in my application. Is this possible?
TomSchuller
This should work
        File newFile = new File("myNewFile.mxd");
        MapDocument mapDocument = new MapDocument();
        mapDocument.esri_new(newFile );
/* if you will save some content in it, just comment below out
        mapDocument.replaceContents(map);
        mapDocument.setActiveView(map);   or        mapDocument.setActiveView(pageLayout);
        mapDocument.save(false, false);
        mapDocument.close();
ViridianaGO
Thank you so much, I´ll try it.
