Edit Annotation Tool - Menu Options - Getting at Convert to Multi/Single Part tool
2639
02-05-2011 11:35 AM
DavidPlume1
Hi Everyone,
I'd like to create some short cuts to point at the Convert to Multi/Single part commands on the Edit Annotation Tool.  These commands are available in the Advanced Editing Commands list but become inactive when posted on toolbars.
It would be very handy to associate some keys or similar short cuts to these commands while in an edit session.  I thought that the code to get to these properties would be pretty "easy" to wire up in VBA or a .NET addin.
I've not even been able to find the interface these properties sit on.  Can anyone offer some insights into which objects manage Annotation Properties at this level?
David
DavidPlume1
OK I've worked out what object(s) manage(s) single/multi part settings.
This doesn't explain why the interface disables the basic command when posted on a toolbar but does give you a way to add this functionality to your own controls.
You derive IMultiPartTextElement from IElement:
(Please forgive the ragged bits in the following development code)
Private Sub ToggleSingleMulti()
On Error GoTo lblError
    Dim pDoc As IMxDocument
    Set pDoc = ThisDocument
    Dim pMap As IMap
    Set pMap = pDoc.FocusMap
    Dim pFeatSel As IEnumFeature
    Set pFeatSel = pMap.FeatureSelection
    Dim pFeat As IFeature
    Set pFeat = pFeatSel.Next
    Dim pAnnoFeat As IAnnotationFeature2
    Dim pElem As IElement
    Dim pTextEl As ITextElement
    Dim pMultTextEl As IMultiPartTextElement
    Dim pAnnoClassExt As IAnnotationClassExtension2
    Set pAnnoClassExt = GetAnnoFeaClsExt(pMap, pDoc)
    If pAnnoClassExt Is Nothing Then
              Exit Sub
    End If
    Do While Not pFeat Is Nothing
        If TypeOf pFeat Is IAnnotationFeature2 Then
            Set pAnnoFeat = pFeat
            Set pElem = pAnnoFeat.Annotation
            If Not pElem Is Nothing Then
                Set pMultTextEl = pElem
                If pMultTextEl.IsMultipart Then
                    pMultTextEl.ConvertToSinglePart
                Else
                    pMultTextEl.ConvertToMultiPart pAnnoClassExt.Display(pElem)
                End If
                pAnnoFeat.Annotation = pElem
                Set pFeat = pAnnoFeat
                pFeat.Store
            End If
        End If
    Loop
    Exit Sub
lblError:
    Debug.Print Err.Description
    Exit Sub
End Sub
Public Function GetAnnoFeaClsExt(pMap As IMap, pMxdoc As IMxDocument) As IAnnotationClassExtension
  'Dim pMxDoc As IMxDocument
  'Set pMxDoc = Nothing
  Dim pID As UID  'Get a handle to the Editor extension
  Set pID = New UID
  Dim pAnnoExt As IAnnotationEditExtension
  Dim pAnnoID As New UID
  pAnnoID = "esriEditor.AnnotationEditExtension"
  Dim pAnnoClass As IAnnotationClassExtension
  pID = "esriEditor.Editor"
  Dim pEditor As IEditor2
  Set pEditor = Application.FindExtensionByCLSID(pID)
  Dim pEditLayers As IEditLayers
  If pEditor.EditState = esriStateNotEditing Then
    MsgBox "Please start the Editor to select points."
    Set GetAnnoFeaClsExt = Nothing
    Exit Function
  End If
  Set pEditLayers = pEditor 'QI to grab CurrentLayer property
   If pEditLayers Is Nothing Then
       return nothing
   End If
 Dim iLayerCount As Integer
 Dim pFeatureLayer As IFeatureLayer
 For iLayerCount = 0 To pMap.LayerCount - 1
    If TypeOf pMap.Layer(iLayerCount) Is IFeatureLayer Then
        Set pFeatureLayer = pMap.Layer(iLayerCount)
        s = pFeatureLayer.Name
        pEditLayers.SetCurrentLayer pFeatureLayer, 0
        Debug.Print pEditLayers.CurrentLayer.Name
    End If
 Next iLayerCount
    Set pAnnoClass = pEditLayers.CurrentLayer.FeatureClass.Extension
    Set GetAnnoFeaClsExt = pAnnoClass
    Exit Function
lblError:
    Exit Function
End Function
