MouseDown pass through of right click
1211
10-18-2010 08:47 AM
RichardFairhurst
I have created a UIToolControl in VBA that I would like to activate only if the left mouse button is clicked within the map.  However, if the right mouse button is clicked I would like the normal ArcMap context menu to be activated.  I know how to test for the left button event, but if all I do is determiine that another button was clicked and exit the sub, no context menu is activated.
Do I have to explicitly call the context menu when the right mouse button is clicked or can I somehow pass the right click event to ArcMap?  What do I need to do to get the right mouse click to activate the normal ArcMap context menu when my tool is active?  Thanks.
NeilClemmons
Honored Contributor
In the code editor, choose ContextMenu from the right-hand dropdown list and have it return False.
RichardFairhurst
Thanks for the reply.  I added the code below but the behavior of the tool has not changed and the code below is not fired.  I still do not get a context menu if the right button is clicked.  What am I missing?
Private Function UIToolControl1_ContextMenu(ByVal x As Long, ByVal y As Long) As Boolean
  UIToolControl1_ContextMenu = False
End Function
RichardFairhurst
Neil thanks for the suggestion.  I got the ContextMenu to work after looking at some of your other older posts.  In addition to setting the ContextMenu value to False I also had to alter the Mousedown behavior to detect the right-click button and send the clicked coordinates to the ContextMenu of the tool.  So the minimum code required to get the behavior I wanted is:
End Function
Private Sub UIToolControl1_MouseDown(ByVal button As Long, ByVal shift As Long, ByVal x As Long, ByVal y As Long)
  If button = 2 Then
    UIToolControl1_ContextMenu x, y
  ElseIf button = 1 Then
    ' Whatever the tool does
  End If
End Sub
