INewLineFeedback.Refresh() not working?
544
10-19-2010 01:08 PM
AlexanderDorofeev
Hi, I'm creating tool that draws line through certain points. For  visualization of the  line I use INewLineFeedBack, but it disappears when display is refreshed. Listening to IActiveView_Rereshed and calling INewLineFeedback.Refresh() on it  does not fix this. What should I do to use INewLineFeedBack in my tool without having troubles with display refresh?
Thanks in advance
this is a piece of my code
ESRI.ArcGIS.Display.INewLineFeedback _lineFeedBack = null;
public override void OnCreate(object hook)
            ESRI.ArcGIS.Carto.IActiveViewEvents_Event activeEvent = (ESRI.ArcGIS.Carto.IActiveViewEvents_Event)GlobalValues.ActiveDocument.FocusMap;
            activeEvent.ViewRefreshed+=new IActiveViewEvents_ViewRefreshedEventHandler(activeEvent_ViewRefreshed);
 void activeEvent_ViewRefreshed(IActiveView view, esriViewDrawPhase phase, object Data, IEnvelope envelope)
            if (_lineFeedBack != null )
                _lineFeedBack.Refresh(GlobalValues.ActiveDocument.ActiveView.ScreenDisplay.hDC);
 public override void OnMouseDown(int Button, int Shift, int X, int Y)
  if (_lineFeedBack == null)
                            _lineFeedBack = new ESRI.ArcGIS.Display.NewLineFeedbackClass();
                            _lineFeedBack.Display = GlobalValues.ActiveDocument.ActiveView.ScreenDisplay;
                            ESRI.ArcGIS.Display.IRgbColor rgbColor = new ESRI.ArcGIS.Display.RgbColorClass();
                            rgbColor.Red = 0; rgbColor.Green = 255; rgbColor.Blue = 0;
                            ESRI.ArcGIS.Display.ISimpleLineSymbol symbol=(ESRI.ArcGIS.Display.ISimpleLineSymbol)_lineFeedBack.Symbol;
                            symbol.Color = rgbColor;
                            _lineFeedBack.Start(featPoint);
                        else
                            _lineFeedBack.AddPoint(featPoint);
public override void OnMouseMove(int Button, int Shift, int X, int Y)
IPoint point= GlobalValues.ActiveDocument.ActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(X, Y);
                if (_lineFeedBack != null) _lineFeedBack.MoveTo(point);
