Hello all,I'm building a tool that gathers all Maplex labelproperties for all labelclasses of all layers in an mxd. The result is stored in a csv-file, to get a sort of overview.In the code below i'm using IMaplexOverposterLayerProperties to access these labelproperties. The problem is that i can't access all the properties that are visible in de Maplex placement dialogs. One of them is the checkbox Measure offset from feature geometry that is in the dialog Layer Properties->Placement Properties->Label Position->Label Offset of a point featureclass.Can somebody tell me the way to access this setting?Greetings, Henk
Private Function processAnnotation(pFeatureLayer As IFeatureLayer)
Dim pAnnoPropsCol As IAnnotateLayerPropertiesCollection
Dim pAnnoProps As IAnnotateLayerProperties
Dim pOverProps As IOverposterLayerProperties
Dim pLabelEngineLayerProperties2 As ILabelEngineLayerProperties2
Dim pMaplexOverposterLayerProperties As IMaplexOverposterLayerProperties
Dim pGeoLayer As IGeoFeatureLayer
Set pGeoLayer = pFeatureLayer
If pGeoLayer.DisplayAnnotation Then
Set pAnnoPropsCol = pGeoLayer.AnnotationProperties
Dim i As Long
For i = 0 To pAnnoPropsCol.count - 1
pAnnoPropsCol.QueryItem i, pAnnoProps
Set pLabelEngineLayerProperties2 = pAnnoProps
Set pMaplexOverposterLayerProperties = pLabelEngineLayerProperties2.OverposterLayerProperties
Print #lFileId, "Placement Method: " & pMaplexOverposterLayerProperties.PointPlacementMethod
Print #lFileId, "Can Shift Point Label " & pMaplexOverposterLayerProperties.CanShiftPointLabel
Next i
End If
End Function
