Java ArcObjects SDK: problem with ArcGIS Java Configuration Tool
2265
11-05-2015 06:35 AM
BarbaraSchneider1
I am creating an ArcMap Add-In using Java ArcObjects SDK. I want to attach my code (or debugger) to ArcMap. I have found the following instructions:
http://resources.esri.com/help/9.3/arcgisserver/adf/java/help/doc/4ecc7c38-c7d9-4e99-bcf4-de28ab770f...
When I use the JavaConfigTool.exe (in ARCGISHOME/bin), I always get the following error: "Error, could not create a registry key."
Thanks for any help in advance,
Barbara
BarbaraSchneider1
I have found the solution: JavaConfigTool.exe has to be run as an Administrator:
ArcObjects Help for Java developers
