ISimpleJunction
1470
04-22-2014 11:17 PM
JonGarrido
I want to run this sample code just to manage the edges of a selected feature (junctionFeature)...
// Assume we already have a pointer to a junction feature.
ISimpleJunctionFeature simplejunctionFeature = junctionFeature;
IEdgeFeature edgeFeature;
IRow row;
for(int i = 0; i < simplejunctionFeature.EdgeFeatureCount; i++)
    edgeFeature = simplejunctionFeature.get_EdgeFeature(i);
    row = (IRow)edgeFeature;
    Console.WriteLine("EdgeFeature " + i + " has OID of: " + row.OID);
Well, first Im trying another code.
I have an IFeature selected . I have notice that when I hit a breakpoint for debbuging the FeatureType property of this element is esriFTSimpleJunction.
The code is this:
try
                    ISimpleJunctionFeature junction = firstSelectedFeature as ISimpleJunctionFeature; //firstSelectedFeature is my IFeature
                    staticUtilities.writeToDockableWindowJon(junction.EdgeFeatureCount.ToString()); //this just writes in my dockable window textbox...
                catch (Exception ex)
                    staticUtilities.writeToDockableWindowJon(ex.ToString()); //this just writes in my dockable window textbox...
The error is this:
System.Runtime.InteropServices.COMException (0x80004005): Error no especificado (Excepción de HRESULT: 0x80004005 (E_FAIL))
   en ESRI.ArcGIS.Geodatabase.ISimpleJunctionFeature.get_EdgeFeatureCount()...
Pleas help!!!
Thans in advance
Jon
JonGarrido
After a lot of tests... I have realized that the code works well with a the geometric network imported in an sde geodatabase...
I've noticed that in the filegeodatabase:
-  simplejunctionFeature.EID is always 0
-  simplejunctionFeature.EdgeFeatureCount throws the explained exception
-   the original IFeature.hasOID property is false and and OID throws a exception as well.
What's the reason of this? I need the code to work on a filedatabase!!
Thanks in advance,
Jon
Complete code now:
      ISimpleJunctionFeature simplejunctionFeature = firstSelectedFeature as ISimpleJunctionFeature;
                IRow row;
                try
                    for (int i = 0; i < simplejunctionFeature.EdgeFeatureCount; i++)
                        staticUtilities.writeToDockableWindowJon("EdgeFeature " + i + " has OID of: " + row.OID);
                catch (Exception ex) {
JonGarrido
Hi everybody!!
Any idea of this stuff? I need this code to run at a filegdb as well...
Please help!!
Thanks in any case..
Jon
