Interface for mouse cursor symbols?
1433
08-10-2010 08:44 AM
DavidNewman
I haven't been able to find documentation on this, if it exists. Is there a programmatic way to connect symbols to the mouse cursor in the way that the "Create Features" pane does? I've looked at ISystemCursor, but it doesn't appear to control that functionality.
>>Dave
vincentLahaye
i don't know if it's what you are looking for, but this line change cursor to an hourglass cursor mouse
System.Windows.Forms.Cursor.Current = Cursors.WaitCursor;
Other type of cursor are available.  Normal cursor is Cursors.Default
Vincent
DavidNewman
Thanks, but I'm not looking for the standard cursors. I'm trying to change the cursor to match the symbol of a map feature.
AlexanderAnkrah
If you've not already solved this you can do something like this on your onmousedown event.
function changeCursor(cursors) {
    switch (cursors) {
        case "pan":
            dojo.byId("Map_Panel_layers").style.cursor = "url('images/cursors/hndopen.cur'),crosshair";
            down = dojo.connect(map, "onMouseDown", function(evt) {
                dojo.byId("Map_Panel_layers").style.cursor = "url('images/cursors/hndclosed.cur'),crosshair";
            dojo.connect(map, "onMouseUp", function(evt) {
            //dojo.byId("map_zoom_slider").style.cursor = 'default';
            //dojo.byId("map_infowindow").style.cursor = 'default';
            //dojo.byId("navToolbar").style.cursor = 'default';
            break;
