IDataset FullName property always null
2122
03-03-2016 11:55 AM
JosephSaltenberger
I am triyng to access the FullName property of IDataset, but FullName is always null (incidentsDataset.FullName below)
Here is the code I'm using:
            IMxDocument mxdoc = ArcMap.Application.Document as IMxDocument;
            IMap map = mxdoc.FocusMap;
            IEnumLayer enumLayer = map.Layers;
            ILayer layer = enumLayer.Next();
            IFeatureLayer2 incidentsFLayer = null;
            while (layer != null)
                if (layer.Name == "Incidents" && layer is IFeatureLayer2)
                    incidentsFLayer = layer as IFeatureLayer2;
                IFeatureClass incidentsFC = incidentsFLayer.FeatureClass as IFeatureClass;
                IDataset incidentsDataset = incidentsFC as IDataset;
                IFeatureClassName incidentsFCName = incidentsDataset.FullName as IFeatureClassName;
Thanks.
Tags (1)
YuanLiu
Hi, do you mean the IName object returned by incidentsDataset.FullName  is null, or its NameString is empty? I tested your code snippet, and was able to get a valid IName object as well as a valid IFeatureClassName after casting. Though the NameString is empty (which is a known issue http://resources.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#//00420000014z000000 ), we can use the IName.Open method to open the feature class. if you would like to get the name string, you may consider using IDataset.Name property instead.
