I need help on this error message
1553
6
08-07-2012 03:04 PM
OLANIYANOLAKUNLE
I was trying to write a custom python script for Definition query for a particular layer and this error message was what i got
NameError: name 'field' is not defined
after entering the following codes -
#Variables to form defintion query
field = '"Name_Allottee"'
value = "'Fadare A Adetoye'"
#concatenate query syntax
queryStr = "Name_Allottee" + "=" + "Fadare A Adetoye"
#Specify the MXD project (CURRENT), dataframe (Layers)
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")
#Apply defintion query to specified layer group (KWAGIS_Parcels)
for lyr in arcpy.mapping.ListLayers(mxd, "KWAGIS_Parcel", df):
if lyr.supports("DEFINITIONQUERY"):
lyr.definitionQuery = queryStr
arcpy.RefreshActiveView()
BruceNielsen
Try this:
queryStr = "\"Name_Allottee\" = 'Fadare A Adetoye'"
In a query string, field names need to be enclosed in double quotes, and string values in single quotes.
OLANIYANOLAKUNLE
Do you have any python script that can clip the data frame extent to a selected feature, a script different from the clipping under the geoprocesssing tool?
Thanks a bunch
OLANIYANOLAKUNLE
the Code:
queryStr = "\"Name_Allottee\" = 'Fadare A Adetoye'" seems not to work with my layer under a parcel fabric i.e. my layer is a parcel layer under a parcel fabric dataset and when i run dis definitionquery for the parcel layer it does not return any results, what would return a result is this sql statement - [Name_Allottee] = 'Fadare A Adetoye', how can i put this into my python script below and make it work?
import arcpy
import pythonaddins
import os
        mxd = arcpy.mapping.MapDocument("Current")
        df = arcpy.mapping.ListDataFrames(mxd)[0]
        lyr= arcpy.mapping.ListLayers(mxd,"Parcels")[0]
        lyr.definitionQuery = '"Name_Allot" =\'Fadare A Adetoye\''
        arcpy.RefreshTOC
Thanks - what i want is how to concatenate the lyr.definitionquery for features in a geodatabase
OLANIYANOLAKUNLE
        lyr.definitionQuery = '"Name_Allottee" =\'Fadara A Adatoyo\''
        arcpy.RefreshTOC()
OLANIYANOLAKUNLE
i used the following python script to create a script tool to select an attribute of a particular feature, but it returns all the records of the feature specified in the FeatureClass;
import arcpy
arcpy.env.overwriteOutput = True
try:
    # Get the input parameters for the selection tool
    FeatureClass = arcpy.GetParameterAsText(0)
    SQLStatement = arcpy.GetParameterAsText(1)
    # Select by Layer Attribute
    arcpy.SelectLayerByAttribute_management(FeatureClass, "NEW_SELECTION", "")
    # Report a success message
    arcpy.AddMessage("All done!")
except:
    # Report an error messages
    arcpy.AddError("Could not complete the selection")
    # Report any error messages that the selection tool might have generated
    arcpy.AddMessage(arcpy.GetMessages())
Please any suggestions. Thanks
BruceNielsen
A SelectLayerByAttribute statement without the query statement is like saying "SELECT ALL FROM...". Since you're accepting a SQL statement as a parameter, I believe you want something like this:
arcpy.SelectLayerByAttribute_management(FeatureClass, "NEW_SELECTION", SQLStatement)
