How to use an attribute field to define Polyline With?
1653
06-10-2010 08:09 PM
chriss_
Hi!
I've a polyline layer for streets. Int this Layer I ve an attribute field "Counts". Now I want to display each polyline depending on the value in the "Counts" field.
Let s say i ve 10 Features in this layer. The highest Value for all features is "Counts" =1000. So I want to display this with a width of lets say 10 and the other Features with lower values for "Counts" correspondingly. So a "Counts"= 100  would be a width of 1.
Anyone has an idea?
Thanks for your help
Chris
AlexanderGray
Honored Contributor
Hi Chris,
this isn't really an ArcObjects question, well at least my answer isn't.  You can symbolize your layer in ArcMap based on quantities and a proportial symbol.  So if you had a count field in your line feature class defined as a numeric field, you could use that as a quantity.  Then you can set your min and max width and all that good stuff.
MelitaKennedy
Esri Notable Contributor
Hi Chris,
Given Alexander's answer, I found IProportionalSymbolRenderer in the SDK help. It's in the Carto library.
Melita
chriss_
Hi!
Thanks for both replies.
@Melita:that was exactly the keyword i was looking for. With this I found some nice postings in the old forum.
For anybody who has the same problem my Code is here:
Private Sub zankeyflow()
Dim pMxDoc As IMxDocument
Set pMxDoc = ThisDocument
Dim pMap As IMap
Set pMap = pMxDoc.FocusMap
Dim pFeatLayer As IFeatureLayer
Set pFeatLayer = pMap.Layer(0)
Dim pFeatClass As IFeatureClass
Set pFeatClass = pFeatLayer.FeatureClass
Dim pProportionalSymbolRenderer As IProportionalSymbolRenderer
Dim pLineSymbol As ILineSymbol
Set pProportionalSymbolRenderer = New ProportionalSymbolRenderer
Dim pGeoFeatLayer As IGeoFeatureLayer
Set pGeoFeatLayer = pFeatLayer
pGeoFeatLayer.DisplayField = "Line_ID"
Dim pTable As ITable
Dim pCursor As ICursor
Dim pRow As IRow
Dim pQueryFilter As IQueryFilter
Set pQueryFilter = New QueryFilter
pQueryFilter.AddField "Line_ID"
Set pTable = pGeoFeatLayer
Set pCursor = pTable.Search(pQueryFilter, False)
Dim pData As IDataStatistics
Dim pResults As IStatisticsResults
Set pData = New DataStatistics
pData.Field = "Line_ID"
Set pData.Cursor = pCursor
Set pResults = pData.Statistics
Dim pRGB As IRgbColor
Set pRGB = New RgbColor
pRGB.Red = 255
pRGB.Green = 0
pRGB.Blue = 0
Set pLineSymbol = New SimpleLineSymbol
pLineSymbol.Color = pRGB
pRGB.Red = 0
pRGB.Green = 255
pRGB.Blue = 0
pLineSymbol.Width = 1
With pProportionalSymbolRenderer
.ValueUnit = esriUnknownUnits
.ValueRepresentation = esriValueRepUnknown
.Field = "Line_ID"
.FlanneryCompensation = True
.MinDataValue = pResults.Minimum
.MaxDataValue = pResults.Maximum
.MinSymbol = pLineSymbol
.LegendSymbolCount = 3
.CreateLegendSymbols
End With
Set pGeoFeatLayer.Renderer = pProportionalSymbolRenderer
pMxDoc.ActiveView.ContentsChanged
pMxDoc.UpdateContents
pMxDoc.ActiveView.Refresh
End Sub
