How to split polyline at vertices?
1331
06-27-2012 01:52 PM
InsuHong1
How can I split polyline at its vertices?
There is SplitLine tools in geoprocessing, but generate geoprocessing object and execute it is slow.
Is there any other way to split?
Thanks.
Insu
DimaShats
Do you want to split using ArcEngine?
Did you try IPolycurve.SplitAtPoint ?
Best Regards, Dima.
Thanks.
Insu
InsuHong1
Yes. I tried, but failed.
Here's my code for that.
                IPolyline plConvexHullLine = (IPolyline)igConvexHullLine;
                for (int e = 0; e < pcVertices.PointCount; e++)
                    IPoint ptIn = pcVertices.get_Point(e);
                    int f;
                    int g;
                    Boolean k;
                    plConvexHullLine.SplitAtPoint(ptIn, false, true, out k, out f, out g);
is there any problem with my code?
DimaShats
If you want to split your polyline at any vertex, maybe you should to use ISegmentCollection objSegmentCol = igConvexHullLine as ISegmentCollection;
do you mean to this result?
                    int f;
                    int g;
                    Boolean k;
