How to check if spatial reference system is GCS or PCS?
1304
12-15-2010 01:25 PM
PaulSchmidt1
for an application I have to get the unit of the coordinate system of a featureClass. (I'm using VBA)
What I do is: I take the layer with the FeatureClass. Then give the Layer to IGeoDataset. The Reference System of the dataset I pass to IGeographicCoordinateSystem or IProjectedCoordinateSystem. Finaly i get the unit from IUnit.
My problem is: Bevor I pass to IGeographicCoordinateSystem or IProjectedCoordinateSystem, I have to know, if it is a GCS or a PCS. Otherwise I get an error.
I didn't find out how I can check this before.
Does anyone of you have an idea?
MelitaKennedy
Esri Notable Contributor
You should be able to use something like this:
    If TypeOf pSpatialReference Is IGeographicCoordinateSystem Then
        MsgBox "GeographicCoordinateSystem"
    End If
    If TypeOf pSpatialReference Is IUnknownCoordinateSystem Then
        MsgBox "UnknownCoordinateSystem"
    End If
    If TypeOf pSpatialReference Is IProjectedCoordinateSystem Then
        MsgBox "ProjectedCoordinateSystem"
    End If
Melita
