How do I obtain the code value domain from a Maplayer in version 10.2.2?
3351
12-09-2015 01:55 PM
GenaroGarcia
I am writing a standalone mobile application that consume the mapcache data to a map viewer in Version 10.2.2
I want to create a search tool that contains a combo-box  which I want to auto-populate it with the values of the layer's field domain.
How do I obtain the domain codes and values of a field with the MapLayers.
GenaroGarcia
Private Sub Get_Street_Names_From_Domain()
' --- Get Code and Street name from Street layer
Try
     ' --- Street layer - Get Street Domain
     Dim pSource As FeatureSource = VectorMobileCache.FeatureSources(g_Street_LP)
     pSearchSource = pSource
     Dim pDomain As IDomain
     pDomain = pSource.Columns("STR_CODE").GetDomain(0)
     Dim pSW As Workspace = pSource.Workspace
     Dim pCV As CodedValueDomain = CType(pDomain, CodedValueDomain)
     ' --- Get count
     gStreetArrayCount = pCV.Rows.Count
     ' --- If count is greater than zero
     If gStreetArrayCount > 0 Then
          Dim i As Integer
          ' --- Loop thru rows to get code and street name
          For i = 0 To gStreetArrayCount - 1
               gStreetArray(0, i) = pCV.Rows(i).Item(0)                 'Code
               gStreetArray(1, i) = pCV.Rows(i).Item(1)                 'Description
               gStreetArray(2, i) = UCase(pCV.Rows(i).Item(1))    'Description in upper case
          Next I
     Else
          MessageBox.Show("Problems obtaining Street Names domain.", "Street Domain - Error",
                                            MessageBoxButtons.OK, MessageBoxIcon.Information)
     End If
     Catch ex As Exception
          g_ErrorMessage = " - Viewer - Problems obtaining Street Names domain:  " & ex.Message.ToString
          WriteLog(g_ErrorMessage)
     End Try
End Sub
'___________________________________________________________________________________
GenaroGarcia
Try
     ' --- Get count
          Dim i As Integer
          Next I
     Else
     End If
     End Try
End Sub
