How can I get the IProximityOperator.ReturnDistance value in display units?
1281
05-21-2010 09:14 AM
RobertDone
I have a VBA script that computes nearest neighbor distances and returns those distances in map units (decimal degrees) but I need them in display units (meters, miles, etc.). How can I do this? Thanks in advance.
Durga_PrasadD
  1. IProximityOperator.ReturnDistance  returns distance in current map projection,in your case it might be WCS.
  2. You have to project the input data into a projected coordinate system like UTM.
  3. Then,use IProximityOperator.ReturnDistance on the projected  values to get distnace in meters(or any other unit).
ThavitinaiduGulivindala
Use IUnitConverter interface to convert the value from mapUnits to DisplayUnits
MapUnits - IMap.MapUnits
Display Units - IMap.DistanceUnits
Cheers,
Thaviti
