Hillshade error
4328
09-29-2014 12:20 PM
FerasObeidat
Hello all,
I have the following error when running HillshadeCommand
Opening raster workspace C:\Program Files (x86)\ArcGIS\DeveloperKit10.2\java\samples\data\raster\dem1 and getting its dataset ...
AutomationException: 0x80041018 - Failed to open raster dataset in '"esriDataSourcesRaster.GdalRasterDataset"'
  at com.esri.arcgis.datasourcesraster.RasterWorkspace.openRasterDataset(Unknown Source)
  at HillshadeCommand_.createHillshade(HillshadeCommand_.java:205)
Should I use ArcGIS engine to run raster files or I can still use ArcGIS desktop ? if I need to use ArcGIS engine how can I install it?
The contents of raster directory on my computer is displayed in this attachment"
Thanks
Feras
EricBader
Honored Contributor
The problem could be that the path to the dataset has a space in it. You can either change your System environment variable from "c:\Program Files(x86)\..." to "C:\Progra~2\...", or copy the workspace to a path that does not have a space in it.
Hope this helps.
FerasObeidat
Hi Eric,
I think the problem is that I have a problem in installing the DeveloperKit for Java, do you have the link to the proper installation? Do I need ArcEngine to have the developerKit ? This the link I used for, but this not working with HillshadeCommand ArcGIS for Developers
Thanks
Feras
