Arcgis Engine 10.1 Attempted to read or write protected memory error.
4757
01-15-2013 10:51 AM
KrishnaSista
We are in process of upgrading our sde to 10.1 from 9.3.1. I have a Arcgis engine console application coverted to Arcgis 10.1. The exe runs itself runs fine when i run manually, but when i run as sql job it giving me following error.
"Unhandled Exception:System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt. at ESRI.ArcGIS.esriSystem.AoInitializeClass.IsProductCodeAvailable(esriLicenseProductCode ProductCode) at LicenseInitializer.Initialize() "
According to my understanding we donot have to install arcgis engine developer kit on server. Arcgis engine application should be able to run using desktop license.
Server - Windows server 2008, Enterprise
ArcSDE - 64bit - SP1
Arcgis dekstop - sp1
SQL server 2008 R2
I Set the project to run under - x86 platform
Embed Interop Types - False.
Does anybody have a clue?
NeilDuxbury
We encountered a similar error with a command line application running from Windows Task Scheduler. We had to check the 'Run with highest privileges' option on the General tab of Task properties.
GwenRoyakkers
This exception is thrown usually when you use a variable (or pass it to a function) with a member pointing to another read-only or non-existing (non-initialized) object.
It depends on your code but usually I solve this with the IClone interface.
In a debugger you can usually spot which variable is the culprit.
(in your case it might be needed to put a debug build on the server, and start a remote debugging session to see where it goes wrong)
