Get Feature Class name from MXD layers? (.NET)
1052
12-09-2010 04:12 AM
TonyCollins
Could someone tell me how to retrieve the Feature Class name for each layer in an MXD?
I tried this:
MapControlClass mapControl = new ESRI.ArcGIS.MapControl.MapControlClass();
mapControl.LoadMxFile(filename,null,null);
ESRI.ArcGIS.Carto.IFeatureLayer layer =
(ESRI.ArcGIS.Carto.IFeatureLayer)mapControl.get_Layer(1) as ESRI.ArcGIS.Carto.IFeatureLayer;
But the Feature Class property is null?
JeffreyHamblin
get_Layer() returns an ILayer. So you should use that first, then test if it is an IFeatureLayer.
I haven't worked with MapControl, but I think something like this should work:
for (int i = 0; i < mapControl.LayerCount; i++)
  ILayer layer = mapControl.get_Layer(i) as ILayer;
  if (!(layer is IFeatureLayer))
    continue;
  IFeatureLayer featureLayer = (IFeatureLayer)layer;
  string fName = featureLayer.FeatureClass.AliasName;
  // do something with fName
-Jeff
Venkata_RaoTammineni
I tried this:
ESRI.ArcGIS.Carto.IFeatureLayer ptestLayer = mapcontl.FocusMap.get_Layer(1).Name;
Thanks and Regards,
Venkat
Ariharan
Am also having same problem, If i use some class instead of AxMapControl, getting error as null value in featureclass.
Have anyone got the answer?
