Finding the shortest path using ArcObjects - Geometric network
3074
01-22-2014 11:34 AM
DaveZhang
I am working with a Geometric Network, I would like to find the shortest path for two given points and get the path geometry. I know the Utility Network Analyst does this. but it only draw the path, but I need to get the geometry of the path regardless of the flow direction. Is anyone have such experience? Any hint or any piece of codes would be very appreciated.
thank you in advanced.
nicogis
MVP Alum
I have made soe but you can see code for your logic.
http://www.arcgis.com/home/item.html?id=19b9b7cd07f74727b94532e24ddece6d
