FileGeodatabase adding, and topology ...
634
06-16-2010 11:30 AM
thomaslepkowski
Hello,
I'm trying to insert a polygon into my fileGeodatabase feature class.  Previously this worked fine, until I made the feature class participate in a topology.  Now I get
"Objects in this class cannot be updated outside an edit session" exception.
Ok, fine, so I'll make an edit session, but I get the same exception.
Here's the code:
IWorkspace workspace = fileGDBWorkspaceFactory.openFromFile( "/foo/highPitch.gdb" );
IFeatureWorkspace featureWorkspace = (IFeatureWorkspace) workspace;
IWorkspaceEdit workspaceEdit = (IWorkspaceEdit) workspace;
workspaceEdit.startEditing(false);
workspaceEdit.startEditOperation();
IFeatureClass featureClass = featureWorkspace.openFeatureClass("module");
IFeature newFeature = featureClass.createFeature();
newFeature.setShapeByRef(module.getPolygonElement().getGeometry());
newFeature.store();
workspaceEdit.stopEditOperation();
workspaceEdit.stopEditing(true);
Any thoughts on adding a feature to a feature class that participates in a topology?  Thanks in advance for any pointers!
thomaslepkowski
When initializing arcGIS Engine, you need to specify the correct license level (esriLicenseProductCode.esriLicenseProductCodeEngineGeoDB), like so:
try {
com.esri.arcgis.system.AoInitialize ao = new com.esri.arcgis.system.AoInitialize();
// NOT esriLicenseProductCodeEngine
//ao.initialize(com.esri.arcgis.system.esriLicenseProductCode.esriLicenseProductCodeEngine);
//  esriLicenseProductCodeEngineGeoDB enables more geodatabase functionality, such as topology
ao.initialize(com.esri.arcgis.system.esriLicenseProductCode.esriLicenseProductCodeEngineGeoDB);
} catch (Exception e) {
   // D'Oh!
