Export Table into textfile
804
09-23-2010 09:46 AM
ludoDupuis
Hi folks,
I am wondering what type of exporter should I use to export tables (as standalonetable) to get file.txt
There is a lot of exporter to export into jpeg, tiff etc... and  there is a possibility to select txt format in the Exportdialog. Unfortunately  I do not find any solution to write a macro with VB to create a txt file of the attribute table ...
Cheers
and thank you
L.
JamesCrandall
Hi folks,
Cheers
and thank you
L.
The only example I have on hand at the moment will create a comma-delimited CSV/.txt file for an ADO.NET DataTable, but you could very well replace this with the rows in a standalone Table in ArcGIS.
Anwyay, hope this helps!
james
untested
Dim CSVFile As System.IO.StreamWriter
CSVFile = New System.IO.StreamWriter("C:\FileNameToCreate.txt")
Dim sb As New System.Text.StringBuilder
sb = New System.Text.StringBuilder
CSVFile.WriteLine("Field1, Field2, Field3, Field4, Field5")
Using CSVFile
     For Each r As DataRow In theADONetDataSet.Tables(0).Rows
           sb.Append((r("Field1")) & "," _
                      & (r("Field2")) & "," _
                      & (r("Field3") & "," _
                      & (r("Field4")) & "," _
                      & (r("Field5"))))
           CSVFile.WriteLine(sb.ToString)
 End Using
ThavitinaiduGulivindala
I dont know if there is any method that exports the data from Stand alone table to text file at a go.
But, ESRI has a way to create text file using TextFileWorkspaceFactory class.
Following is the example from EDN to open text file as a Table. Hence I feel, you can create text file as Table and load the Data from source table into Text file.
// Create a new TextFile workspacefactory and open the workspace
IWorkspaceFactory workspaceFactory = new TextFileWorkspaceFactoryClass();
ESRI.ArcGIS.Geodatabase.IWorkspace workspace = workspaceFactory.OpenFromFile(
    "c:\\temp\\testing", 0);
// Cast for IFeatureWorkspace
ESRI.ArcGIS.Geodatabase.IFeatureWorkspace featureWorkspace = (IFeatureWorkspace)
    workspace;
// Open a table
ESRI.ArcGIS.Geodatabase.ITable oledbTable = featureWorkspace.OpenTable("farms.txt");
http://resources.esri.com/help/9.3/arcgisengine/dotnet/c68303f6-8360-40c0-9faa-e0efdcc44c86.htm
