Display Oracle Spatial geometry
2858
06-16-2010 06:45 AM
amirshauli
Hi all,
I have some geometries (about 5,000) that is store in Oracle Spatial as SDO_GEOMETRY
What will be the best and fastest way to get those geometries from oracle and display them in the map (ArcObjects).
I think of WKT,WKB, GML, UDT (user define type that represent sdo_geometry).
BTW
I don't have SDE and I don't want to use SDE.
Any help?
amirshauli
I want to change my question.
I checked and the fastest way to query those geometries from oracle spatial is UDT (User Defined Type).
The question is can ESRI read the UDT (oracle SDO_GEOMETRY)?
Or should I do some parsing in order to display it?
maybe It will be faster to use WKT because ESRI is familiar with the UDT format?
amirshauli
I meant maybe It will be faster to use WKT because ESRI is NOT familiar with the UDT format?
any help here?
amirshauli
Thanks.
It's good to know ESRI have this functionality.
But actually I need something little different.
I can't let the client access the DB directly (security), So I have a server that pulls the geographic data for the clients and pass it on to them. I want to be able to take this data (UDT is the best way I think) and display it on the map.
How can I do it?
Can ESRI know how to read the SDO_GEOMETRY (UDT) type?
Should I need to cast the UDT to something else that ESRI can read?
