Count only selected features
5050
12-14-2010 11:57 AM
MikeLouwrens
I am wanting my tool to run only on selected features - so if there are no features selected (manually using the Selection tool within ArcMap) the tool won't run.
How do I count the number of selected features, or find if the number selected is greater than 0?
Currently doing this in VBA (ArcGIS 10).
Cheers,
Mike.
MikeLouwrens
Haha if only I'd read through my other code in VBA - I've done this before, only a few months ago 🙂
Here's all I needed
    Dim pDisplayTable As IDisplayTable
    Set pDisplayTable = pFeatLayer
    Dim pSelSet As ISelectionSet
    Set pSelSet = pDisplayTable.DisplaySelectionSet
    Dim pCount As Integer
    pCount = pSelSet.count
    If pCount = 0 Then
        MsgBox "Nothing Selected"
        Exit Sub
    End If
Cheers,
Mike.
FrankKish
You could also use "pMxdoc.FocusMap.SelectionCount"
Such as in ...
Private Sub main()
    Dim pMxdoc As IMxDocument
    Set pMxdoc = ThisDocument
    If pMxdoc.FocusMap.SelectionCount = 0 Then
        MsgBox "No feature selected...Exiting"
        Exit Sub
    End If
    Dim pEnumFeature As IEnumFeature
    Set pEnumFeature = pMxdoc.FocusMap.FeatureSelection
    Dim pF As IFeature
    Set pF = pEnumFeature.Next
    Do Until pF Is Nothing
        ''do something with each feature
    Loop
End Sub
MikeLouwrens
Not quite, as this gives total selected features within the map document, not per layer (I just realised I hadn't specified that in my OP) - my script loops through all layers, and runs on the layer if there are selected features in that layer.
Thanks for your reply,
Mike.
