BaseCommand not working in ArcGIS10
1271
11-04-2010 06:54 AM
MarilynGambone
I created an ArcCatalog base command class in ArcGIS 9.3.1.  I've upgraded to ArcGIS10 and now when I create a custom toolbar, I don't see it listed in the "Commands" tab.
Is there a new way to do this in ArcGIS10?  I had to replace several dlls because they've been deprecated:  ESRI.ArcGIS.ADF is now replaced with ESRI.ArcGIS.ADF.Local and ESRI.ArcGIS.ADF.Connection.Local.
Where does ArcGIS10 put the base.m_catagory, m_caption, etc?  Are these obsolete too?
Any assistance is greatly appreciated.
MarilynGambone
Never mind.  Found out that now I have to click the "Customize" down arrow beside the toolbar and then click, "Add from file..." button and select from the bin folder the ".tlb" file.
RichardLesperance
This answer isn't good enough.  We have to have the ability to install this without the user having to "add from file."  This thread still needs an answer.
