VBA programmatically use cursor to draw a rectangle on a topology
2075
5
12-09-2010 09:50 AM
sailiTang
   I would like to use cursor to draw a rectangle on a topology. And then all the nodes within the rectangle will change color automatically. Please see the attachment. Anybody knows how to write the code?
Thank you.
Venkata_RaoTammineni
You r looking for graphic rectangle or feature rectangle ?
Thanks and Regards,
Venkat
sailiTang
Hi Venkat,
    I think what I need should be graphic rectangle. Actually, the purpose of drawing a rectangle is selecting a topology area. And then I would like to make a different color for all the nodes within this area.
Saili
You are looking for the same ?
  public override void OnMouseDown(int Button, int Shift, int X, int Y)
            try
                // TODO:  Add SelectByShape.OnMouseDown implementation
                IMxDocument pMxDoc = m_application.Document as IMxDocument;
                IEnvelope pEnv;
                IRubberBand pRubberBand;
                IElement pElem;
                //creat new rubber envople
                pRubberBand = new RubberEnvelopeClass();
                pEnv = pRubberBand.TrackNew(pMxDoc.ActiveView.ScreenDisplay, null) as IEnvelope;
                //create new envolpe element
                pElem = new RectangleElementClass();
                pElem.Geometry = pEnv;
                IFillShapeElement pFillShapeElement;
                IFillSymbol pFillSymbol;
                IColor pColor;
                ILineSymbol pLineSymbol;
                IGraphicsContainer pGContainer;
                pFillShapeElement = pElem as IFillShapeElement;
                //set fill symbol
                pFillSymbol = pFillShapeElement.Symbol;
                pColor = pFillSymbol.Color;
                pColor.Transparency = 0;
                pFillSymbol.Color = pColor;
                //set the outline symbol;
                pLineSymbol = pFillSymbol.Outline;
                pColor.Transparency = 255;
                pColor.RGB = 255;
                pLineSymbol.Width = 12;
                pFillSymbol.Outline = pLineSymbol;
                //assing the symbol to teh rectangle
                pFillShapeElement.Symbol = pFillSymbol;
                //add rectange to the GC;
                pGContainer = pMxDoc.ActiveView as IGraphicsContainer;
                pGContainer.AddElement(pElem, 0);
                pMxDoc.ActiveView.Refresh();
                //use rectangle to search the top layer
                ISpatialFilter pSpatialFilter = new SpatialFilterClass();
                IFeatureCursor pFeatCursor;
                IFeature pFeature;
                IFeatureLayer pFeatLayer;
                int intCount = 0;
                pSpatialFilter.WhereClause = "FID >2";
                pSpatialFilter.Geometry = pEnv;
                pSpatialFilter.SpatialRel = esriSpatialRelEnum.esriSpatialRelContains;
                pFeatLayer = pMxDoc.SelectedLayer as IFeatureLayer;
                pFeatCursor = pFeatLayer.Search(pSpatialFilter, false);
                pFeature = pFeatCursor.NextFeature() as IFeature;
                while(pFeature!=null)
                    intCount = intCount + 1;
                    pFeature = pFeatCursor.NextFeature();
                MessageBox.Show("There are " + intCount + "Cities over 5000 Recangel Area");
                pGContainer.DeleteAllElements();
            catch (Exception exp) { }
sailiTang
Hi Venkat,
    Thank you for your code. My other problem is how to write the code for selecting a rectangle area on the topology.
Saili
sailiTang
This is the code which can count the number of nodes and edges of a topology:
Dim pmXDoc As IMxDocument
Dim pTopologyLayer As ITopologyLayer
Dim pTopology As ITopology
Dim pTopoGraph As ITopologyGraph
Dim pEnumTopoNode As IEnumTopologyNode
Dim i As Long
Dim pTopoNode As ITopologyNode
Dim penumNodeEdge As IEnumNodeEdge
Dim pTopoEdge As ITopologyEdge
Dim batfrom As Boolean
Dim pPolyline As IPolyline
Set pmXDoc = ThisDocument
Set pTopologyLayer = pmXDoc.FocusMap.Layer(0) 'A topology has to be in first position in the view Table of content
Set pTopology = pTopologyLayer.Topology 'Get the topology
Set pTopoGraph = pTopology.Cache 'Get the topologygraph
pTopoGraph.Build pmXDoc.ActiveView.Extent, False 'Build the topology graph
Set pEnumTopoNode = pTopoGraph.Nodes 'Get all the nodes of the graph
'For each nodes get the adjacent edges and print the length of the edges
For i = 0 To pEnumTopoNode.Count - 1
   Set pTopoNode = pEnumTopoNode.Next
   Set penumNodeEdge = pTopoNode.Edges(True) 'Get all the adjacent edges
   MsgBox "Number of edges adjacent to that node : " & penumNodeEdge.Count
   MsgBox "Is the enumerator Clockwise : " & penumNodeEdge.IsClockwise
   penumNodeEdge.Next pTopoEdge, batfrom 'Get the next adjacent edge
   While Not pTopoEdge Is Nothing
      Set pPolyline = pTopoEdge.Geometry
      Debug.Print "Length of polyline : " & pPolyline.Length
      penumNodeEdge.Next pTopoEdge, batfrom 'Get the next edge
   Wend
But this code counts the nodes and edges which should be in the whole view. What I want is that the user can use the cursor to select a rectangle area, and then the program can count the nodes and edges which are only in this rectangle area. Please see the attachment. Could you tell me how to write the code for selecting the topology area using cursor?
Saili
