Corrupt Memory Error Message
2395
08-20-2012 08:48 AM
BruceNielsen
I've been using the following code for weeks as part of a larger project (ArcGIS 9.2, Visual Studio 2005). It checks to see if a .dbf file exists in C:\temp. If it doesn't, it copies a template table from an FGDB. Once the .dbf is there, it opens an update cursor on it.
            Const tempDir = "C:\temp"
            Dim pGP As IGeoProcessor = New GeoProcessor
            Dim pParams As IVariantArray = New VarArrayClass
            pGP.OverwriteOutput = True
            '...unrelated code deleted...
            Const strOutDBF = "SumHEL2.dbf"
            Dim gpUtils As IGPUtilities = New GPUtilities
            Dim pGPResult As IGeoProcessorResult
            Dim pTable As ITable
            Dim pCursor As ICursor
            Dim pRow As IRow
            If File.Exists(tempDir + "\" + strOutDBF) Then
                pTable = gpUtils.OpenTableFromString(tempDir + "\" + strOutDBF)
            Else
                pParams.RemoveAll()
                pParams.Add("F:\SD_Tools\HEL_Tool\Hel_1.gdb\sumHEL2_template")
                pParams.Add(tempDir)
                pParams.Add(strOutDBF)
                pGPResult = pGP.Execute("TableToTable_conversion", pParams, Nothing)
                pTable = gpUtils.OpenTableFromString(pGPResult.ReturnValue.ToString)
            End If
            pCursor = pTable.Update(Nothing, True)
            pRow = pCursor.NextRow
Today I've started getting this message whenever the code is executed:
A first chance exception of type 'System.AccessViolationException' occurred in SDtools.dll
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
   at ESRI.ArcGIS.Geoprocessing.GeoProcessorClass.Execute(String Name, IVariantArray ipValues, ITrackCancel pTrackCancel)
   at SDtools.HELanalyze.CreateSumHEL2(IMap pMap, String strFIPS, IFeature pFeat) in C:\Documents and Settings\bruce.nielsen\My Documents\Visual Studio 2005\Projects\SDtools\SDtools\HELanalyze.vb:line 628
The error occurs at either the gpUtils.OpenTableFromString or pGP.Execute line, depending on if the .dbf file exists. Restarting Visual Studio or rebooting the computer had no effect.
Any ideas on why I'm getting this message?
sapnas
Have you tried removing .dbf extension from strOutDBF before adding it to pParams or OpenTableFromString method? The tablename should not have .dbf extension.
BruceNielsen
That wasn't it.
Also: If I run the TableToTable tool manually, it succeeds in copying the template table to C:\temp.
sapnas
The logic that you have provided inputs "SumHel2.dbf" (Const strOutDBF = "SumHEL2.dbf") and not "SumHel2" as a parameter to the outputTable field. Add "SumHel2.dbf" to Output Table field of TableToTable tool in arccatalog and you will notice "invalid name" error.
Danfranco
did you figure out why this was happening?
