Converting Cell Size to Pixel Dimensions
1167
04-03-2014 07:16 AM
BradNace
Hi! I am attempting to cut a 1024x1024 pixel image at the native resolution of the image. In order to do that, I need to know the dimensions of the Clipping Graphic (GraphicSize).
If the projection is in UTM space, the cell size is already in pixels/meters, so the math is fairly easy.
Formula:
GraphicSize = (CellSize *  PixelDimensions)
Example:
512 = (0.5 * 1024)
How will I do that for Decimal Degrees, assuming I cannot convert the layer into UTM space?
Thanks!
BradNace
Nevermind! The Clipping graphic actually uses the native units of layer, so no conversion into meters is needed. The formula works for all projections.
Thanks!
