ConstructCircle - Run-time error '424' Object required. How to fix it?
3937
12
11-22-2011 12:02 AM
MarAlcaraz1
Hi everybody!
Could someone help me with this error? Well, in general, with the whole code, because it returns me different errors. The firs one is about the line pConstCArc.ConstrutCircle. I'd like to convert points from a table to polygons in a feature class.
Thanks in advance for helping me to learn more about ArcObjects!
Private Sub InterpretationTubes_Click()
Dim pSxDoc As ISxDocument
Set pSxDoc = ThisDocument
Dim pScene As IScene
Set pScene = pSxDoc.Scene
Dim i As Integer
For i = 0 To pScene.LayerCount - 1
    If pScene.Layer(i).Name = "InterpretationTubes" Then
    Dim pOutLayer As IFeatureLayer
    Set pOutLayer = pScene.Layer(i)
    End If
Dim pFeatClass As IFeatureClass
Set pFeatClass = pOutLayer.FeatureClass
Dim pStandaloneTC As IStandaloneTableCollection
Set pStandaloneTC = pSxDoc.Scene
Dim pStandaloneT As IStandaloneTable
Set pStandaloneT = pStandaloneTC.StandaloneTable(0)
Dim lng_X, lng_Y, lng_Elevation, lng_SubUnits, lng_Top_Depth, lng_Bottom_Depth As Long
      lng_X = pStandaloneT.Table.FindField("X")
      lng_Y = pStandaloneT.Table.FindField("Y")
      lng_Elevation = pStandaloneT.Table.FindField("Elevation")
      lng_SubUnits = pStandaloneT.Table.FindField("SubUnits")
      lng_Top_Depth = pStandaloneT.Table.FindField("Top_Depth")
      lng_Bottom_Depth = pStandaloneT.Table.FindField("Bottom_Depth")
      If (lng_X < 0) Or (lng_Y < 0) Or (lng_Elevation < 0) Or (lng_SubUnits < 0) Or (lng_Top_Depth < 0) Or (lng_Bottom_Depth < 0) Then
        MsgBox "Could not find specified Fields"
        Exit Sub
      End If
Dim pCur As ICursor
Set pCur = pStandaloneT.Table.Search(Nothing, True)
Dim pRow As IRow
Set pRow = pCur.NextRow
Do While Not pRow Is Nothing
    Dim pPointBot As IPoint
    Set pPointBot = New Point
    pPointBot.x = pRow.Value(lng_X)
    pPointBot.y = pRow.Value(lng_Y)
    pPointBot.Z = pRow.Value(lng_Elevation) - pRow.Value(lng_Bottom_Depth)
    Dim pFeature As IFeature
    Set pFeature = pFeatClass.CreateFeature
    Dim pConstCArc As IConstructCircularArc
    Set pConstCArc = New CircularArc
   pConstrCArc.ConstructCircle pPointBot, 5, True    Error run-time 424: Object required
    Dim pSegCol As ISegmentCollection
    Set pSegCol = New Ring
    pSegCol.AddSegment pConstCArc
    Dim pGeoCol As IGeometryCollection
    Set pGeoCol = New Polygon
    pGeoCol.AddGeometry pConstArc
    Set pFeature.Shape = pGeoCol
    Dim pZAware As IZAware
    Set pZAware = pFeature.Shape
    pZAware.ZAware = True
    pFeature.Value(3) = pRow.Value(lng_SubUnits)
    pFeature.Value(4) = pRow.Value(lng_Bottom_Depth) - pRow.Value(lng_Top_Depth)
    pFeature.Store
    Loop
    pSxDoc.UpdateContents
    pSxDoc.Scene.SceneGraph.Invalidate pOutLayer, True, True
    pSxDoc.Scene.SceneGraph.RefreshViewers
End Sub
MarAlcaraz1
And why is this not valid? It returns the same error on this third line...
Dim pIZ As IZ
Set pIZ = pPolygon
pIZ.SetConstantZ pRow.Value(lng_Elevation) - pRow.Value(lng_Bottom_Depth)
NeilClemmons
Honored Contributor
Where is this at in your code?
MarAlcaraz1
Thanks Neil, I wrote it just above the declaration of pZAware, and it didn't work. I changed it just after pZAware and... IT WORKS!!!! Thank you Neil, I'm so grateful than I even considered send you an iberic ham.
I would like to share the right code with everybody:
Dim i As Integer
End If
Exit Sub
End If
Dim pCur As ICursor
Dim pRow As IRow
Dim pConstrCArc As IConstructCircularArc
Set pConstrCArc = New CircularArc
pConstrCArc.ConstructCircle pPointBot, 10, True
pSegCol.AddSegment pConstrCArc
Set pGeoCol = New polygon
pGeoCol.AddGeometry pSegCol
Dim pPolygon As IPolygon
Set pPolygon = pGeoCol
Dim pZAwarePoly As IZAware
Set pZAwarePoly = pPolygon
pZAwarePoly.ZAware = True
Dim pIZ As IZ
Set pIZ = pPolygon
pIZ.SetConstantZ (pRow.Value(lng_Elevation) - pRow.Value(lng_Bottom_Depth))
Set pFeature.Shape = pPolygon
pFeature.Store
Loop
End Sub
