ConstructCircle - Run-time error '424' Object required. How to fix it?
3909
12
11-22-2011 12:02 AM
MarAlcaraz1
Hi everybody!
Could someone help me with this error? Well, in general, with the whole code, because it returns me different errors. The firs one is about the line pConstCArc.ConstrutCircle. I'd like to convert points from a table to polygons in a feature class.
Thanks in advance for helping me to learn more about ArcObjects!
Private Sub InterpretationTubes_Click()
Dim pSxDoc As ISxDocument
Set pSxDoc = ThisDocument
Dim pScene As IScene
Set pScene = pSxDoc.Scene
Dim i As Integer
For i = 0 To pScene.LayerCount - 1
    If pScene.Layer(i).Name = "InterpretationTubes" Then
    Dim pOutLayer As IFeatureLayer
    Set pOutLayer = pScene.Layer(i)
    End If
Dim pFeatClass As IFeatureClass
Set pFeatClass = pOutLayer.FeatureClass
Dim pStandaloneTC As IStandaloneTableCollection
Set pStandaloneTC = pSxDoc.Scene
Dim pStandaloneT As IStandaloneTable
Set pStandaloneT = pStandaloneTC.StandaloneTable(0)
Dim lng_X, lng_Y, lng_Elevation, lng_SubUnits, lng_Top_Depth, lng_Bottom_Depth As Long
      lng_X = pStandaloneT.Table.FindField("X")
      lng_Y = pStandaloneT.Table.FindField("Y")
      lng_Elevation = pStandaloneT.Table.FindField("Elevation")
      lng_SubUnits = pStandaloneT.Table.FindField("SubUnits")
      lng_Top_Depth = pStandaloneT.Table.FindField("Top_Depth")
      lng_Bottom_Depth = pStandaloneT.Table.FindField("Bottom_Depth")
      If (lng_X < 0) Or (lng_Y < 0) Or (lng_Elevation < 0) Or (lng_SubUnits < 0) Or (lng_Top_Depth < 0) Or (lng_Bottom_Depth < 0) Then
        MsgBox "Could not find specified Fields"
        Exit Sub
      End If
Dim pCur As ICursor
Set pCur = pStandaloneT.Table.Search(Nothing, True)
Dim pRow As IRow
Set pRow = pCur.NextRow
Do While Not pRow Is Nothing
    Dim pPointBot As IPoint
    Set pPointBot = New Point
    pPointBot.x = pRow.Value(lng_X)
    pPointBot.y = pRow.Value(lng_Y)
    pPointBot.Z = pRow.Value(lng_Elevation) - pRow.Value(lng_Bottom_Depth)
    Dim pFeature As IFeature
    Set pFeature = pFeatClass.CreateFeature
    Dim pConstCArc As IConstructCircularArc
    Set pConstCArc = New CircularArc
   pConstrCArc.ConstructCircle pPointBot, 5, True    Error run-time 424: Object required
    Dim pSegCol As ISegmentCollection
    Set pSegCol = New Ring
    pSegCol.AddSegment pConstCArc
    Dim pGeoCol As IGeometryCollection
    Set pGeoCol = New Polygon
    pGeoCol.AddGeometry pConstArc
    Set pFeature.Shape = pGeoCol
    Dim pZAware As IZAware
    Set pZAware = pFeature.Shape
    pZAware.ZAware = True
    pFeature.Value(3) = pRow.Value(lng_SubUnits)
    pFeature.Value(4) = pRow.Value(lng_Bottom_Depth) - pRow.Value(lng_Top_Depth)
    pFeature.Store
    Loop
    pSxDoc.UpdateContents
    pSxDoc.Scene.SceneGraph.Invalidate pOutLayer, True, True
    pSxDoc.Scene.SceneGraph.RefreshViewers
End Sub
NeilClemmons
Honored Contributor
You are declaring the variable as pConstCArc but trying to call it as pConstrCArc.  Notice the "r"?  I would recommend that you go into your VBA settings and check the option to require variable declaration.
MarAlcaraz1
Thanks for the observation Neil, too many hours looking at the computer... But now the problem is with "pGeoCol.AddGeometry pConstrCArc":
The parameter is (or has an element that is) the wrong kind of geometry.
Private Sub InterpretationTubes0_Click()
Dim i As Integer
End If
Exit Sub
End If
Dim pCur As ICursor
Dim pRow As IRow
Dim pConstrCArc As IConstructCircularArc
Set pConstrCArc = New CircularArc
pSegCol.AddSegment pConstrCArc
pFeature.Store
Loop
End Sub
NeilClemmons
Honored Contributor
As stated in the developer help, the geometry collection for a polygon is a collection of rings.  You're trying to add a circular arc to the geometry collection, which is not a ring.  If you want to create a polygon from the circular arc then all you need to do is create a new polygon object, QI to ISegmentCollection and add the circular arc.
Dim polygon As IPolygon
Set polygon = new Polygon
Dim segmentCollection As ISegmentCollection
Set segmentCollection = polygon
segmentCollection.AddSegment circularArc
Of course, your original code will work if you add the segment collection to the geometry collection instead of the circular arc.
MarAlcaraz1
I made some modifications over my code, and it works until the line:
Set pFeature.Shape = pPolygon, where an error is returned: "The geometry has no Z values"
pGeoCol.AddGeometry pSegCol
Set pFeature=PFeatClass.CreateFeature
Dim pPolygon As IPolygon
Set pPolygon = pGeoCol
Set pZAware = pPolygon
Set pFeature.Shape = pPolygon   "The geometry has no Z values"
What am I doing wrong?
NeilClemmons
Honored Contributor
As the error says, you haven't assigned z values to the geometry.  In order to save a feature into a z-aware feature class you must give each point in the geometry a z value.
MarAlcaraz1
It is a bit annoying because I have written a similar code with lines, and it does work!!!
I also checked the "shape" field in the feature class, and it can store three-dimensional features.
Is it not enough to asign Z values with the following code in bold?
In fact, with this code the error says "the geometry has null Z values", instead of "no Z values"...
Dim pZAwarePoint As IZAware
Set pZAwarePoint = pPointBot
pZAwarePoint.ZAware = True
Set pGeoCol = New polygon
'Dim polygon As IPolygon
'Set polygon = New polygon
'Dim segmentCollection As ISegmentCollection
'Set segmentCollection = polygon
'segmentCollection.AddSegment pConstrCArc
Dim pZAwarePoly As IZAware
Set pZAwarePoly = pPolygon
pZAwarePoly.ZAware = True
pFeature.Store
NeilClemmons
Honored Contributor
You're assigning a z value to a point, not the circle.  The circle is never given z values in your code.  Making the circle geometry z-aware doesn't give it z values, it simply makes it so you CAN give it z values.  You still have to assign an appropriate z value to each point in the geometry.  There are several ways to do this so you'll have to choose the way that best suits what you're wanting to do.
MarAlcaraz1
Ok, I understand I didn't say that my circle is on the xy plane, but ConstructCircle should have some parameter to indicate that, shouldn't it?
In any case, i don't know how to get at least two points from pFeature... could you help me, please?
Maybe creating a CircularArc with the same from-to points???
NeilClemmons
Honored Contributor
Z values can be assigned in various ways.  One way is to get each point and assign it a value.  All polygons are a collection of points which can be accessed via IPointCollection.  You loop through each point in the collection and assign the value.  You can also assign z values using the methods on the IZ interface.  If you want all points in the geometry to have the same z value then call SetConstantZ.  If you have a functional surface (i.e. from an elevation model) you can call InterpolateFromSurface.  The other methods such as MultiplyZs and OffsetZs require that z values already be present.
One other thing I noticed in your code - you're specifying the circle to be counter-clockwise in your call to CreateCircle.  A circle that is created CCW is considered a "hole" and will have a negative area.  I don't know if this is what you want or not but thought I'd call it to your attention.
