Change an esricontrol's tooltip
744
06-02-2012 11:27 AM
DavidStreet1
Is there a way to change an esricontrol's tooltip?   I tried using the ICommand interface but the tooltip propertry is read-only.    If I have to build a whole new ICommand and/or ITool is there way I can extend a esricontrol so I do not have to build a new control from scratch?   Thank you.
David
ThavitinaiduGulivindala
David
If u r interested to change tooltip property of an In-Built ESRI command/tool then make use of ICommandItem.
