ArcGIS10 - Add Ins and Dockable Window
13818
15
08-25-2010 02:38 PM
TonyThatcher
Been playing with Add-Ins in 10 using Visual Studio 10 for most of the day.  Interesting stuff.  I seem to be being pushed in this direction with the switch to .NET from VBA, so I'm just diving in.
I have a few examples of buttons, tools, toolbars, etc. up and running, but what I really need to figure out are the Dockable Windows as part of an Add-In.  The documentation is pretty lean in this area other than saying the are "easy" using the new Add-Ins.  I have a Dockable Window added to my Add In, but I am having a heck of a time figuring out how to get it to display.  I'd like to simply click on a button and have the Dockable Window displayed.  It appears that this window should be able to hold the gammut of .NET controls, so I should be able to migrate a bit of my existing VBA Forms over to these Dockable Windows.
Can anyone please point me in the right direction or give a sample?
Thanks much!
-Tony
LesleyBross
Here is my code for popping a Dockable Window from a Button in and add-in where 'DockableWindow1' is the class name for the dockable window class generated by the ESRI add-in wizard.
    Protected Overrides Sub OnClick()
        Dim dockWindow As ESRI.ArcGIS.Framework.IDockableWindow
        ' Only get/create the dockable window if it's not there
        If dockWindow Is Nothing Then
            Dim dockWinID As UID = New UIDClass()
            dockWinID.Value = My.ThisAddIn.IDs.DockableWindow1
            dockWindow = My.ArcMap.DockableWindowManager.GetDockableWindow(dockWinID)
        End If
        dockWindow.Show((Not dockWindow.IsVisible()))
    End Sub
TonyThatcher
Lesley-
Thanks much.  Pretty simple now that I see an example.  One question.  I am getting an error regarding the UID (Type 'UID' is not defined.).  I seem to be missing a reference to somenthing.  Any ideas?  See attached image.
-Tony
TonyThatcher
Hah!  Got it!  Just needed to add 'Imports ESRI.ArcGIS.esriSystem' to the top of the code.
Again, many thanks!  Works like a charm.
-T
JasonMiller
Does anyone have this code in C#?
JMiller
JohnHauck
Here is the code in C#:
UID dockWinID = new UIDClass();
dockWinID.Value = ThisAddIn.IDs.DockableWindow1;
// Use GetDockableWindow directly as we want the client IDockableWindow not the internal class
IDockableWindow dockWindow = ArcMap.DockableWindowManager.GetDockableWindow(dockWinID);
dockWindow.Show(true);
RyanClark
When should the form itself be getting initialized? I've used the code provided here to open up my dockable window, but when it opens I don't see any of the controls that I placed in the UserControl. The InitializeComponent() method is never getting called...
    protected override void OnClick()
            UID theUid = new UIDClass();
            theUid.Value = ThisAddIn.IDs.dwnMapUnitLegendEditor;
            IDockableWindow mapUnitForm = ArcMap.DockableWindowManager.GetDockableWindow(theUid);
            mapUnitForm.Show(true);
    /// <summary>
    /// Designer class of the dockable window add-in. It contains user interfaces that
    /// make up the dockable window.
    /// </summary>
    public partial class dwnMapUnitLegendEditor : UserControl
        public dwnMapUnitLegendEditor(object hook)
            InitializeComponent();
            this.Hook = hook;
        /// <summary>
        /// Host object of the dockable window
        /// </summary>
        private object Hook
            get;
            set;
        /// <summary>
        /// Implementation class of the dockable window add-in. It is responsible for
        /// creating and disposing the user interface class of the dockable window.
        /// </summary>
        public class AddinImpl : ESRI.ArcGIS.Desktop.AddIns.DockableWindow
            private dwnMapUnitLegendEditor m_windowUI;
            public AddinImpl()
                Console.Write("Something");
            protected override IntPtr OnCreateChild()
                m_windowUI = new dwnMapUnitLegendEditor(this.Hook);
                return m_windowUI.Handle;
            protected override void Dispose(bool disposing)
                if (m_windowUI != null)
                    m_windowUI.Dispose(disposing);
                base.Dispose(disposing);
RyanClark
Is it possible to change the width of the dockable window programmatically once it has been initialized? I can change the width of the UserControl just fine, but the dockable window retains its size...
Ryan
CraigPerreault
I have the property Locked = True in my DockableWindow but the user can still resize it.
Can we control the size of the Dockable Window?
SteveFang
Look at IWindowPosition interface if you want to adjust the size of a dockable window programmatically.
