ArcGIS product not specified error
859
11-16-2011 03:59 AM
Almuatasim_Ahmed_SaidAl-Hinai
Hi All,
I am editing the .net application available at: http://arcscripts.esri.com/details.asp?dbid=15497 for exporting and importing from xml document to feature class. But I am getting product licensing error as attached.
I am now that experienced with VB.Net but just trying to utilize this application for data conversion.
Any help is highly appreciated.
Asim
AlexanderGray
The error says you need to bind to an ArcGIS product before you try to check out a license.  Did you bind to the product?
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#/Bind_Method/004600000024...
Dear Alexander, Thanks a lot for your reply.
I am not really sure how to bind to the product. My AD skills is very basic. I will be quite glad if you can please check the attached licenseInitilizer file (where I am getting the error) and guide me where to add the code for binding the product.
Thanks a lot
Asim
AlexanderGray
the code does not belong in the license initializer.  It should be added before the call to that.
Since the project you linked to is 9.2 I suggest you read through and go through every step in the migrating to ArcGIS 10 document.
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/How_to_migrate_ArcGIS_9...
Thanks Alexander,
I can understand the issue now. I will go through the said migration stages and shall update the thread with the result.
My Regards,
Asim
