Accessing current workspace using an ArcObjects add-in for ArcMap
7810
6
07-31-2011 12:02 PM
PaulLivingstone
New Contributor III
I am trying to create a point feature in ArcObjects for an ArcMap add-in in c#. To do this I need to get the feature class. To get the feature class I need to know the current workspace.
How do I find the current workspace opened from ArcMap from within the dockable window c# code?
Any help would be appreciated.
Thanks
Paul
RichardWatson
Application
MxDocument
FocusMap
Layers - IFeatureLayer
FeatureClass - IFeatureClass
IDataset
Workspace
If you search the samples, I suspect that you will find the code.
PaulLivingstone
New Contributor III
Thanks for the quick response Richard.
To help anyone else that is looking, the current workspace can be found via:
   IWorkspace ws = ((IDataset)ArcMap.Document.ActiveView.FocusMap.Layer[0]).Workspace;
OliverBurdekin
Looks good.  Any ideas how to rewrite that for Java?
LeoDonahue
Occasional Contributor III
Here is a sample for opening a shapefile.  Or did you want to get the workspace from an existing layer in the map?
        IWorkspace workspace;
        IWorkspaceFactory workspacefactory;
        IFeatureWorkspace featureworkspace;
            workspacefactory = new ShapefileWorkspaceFactory();
            workspace = workspacefactory.openFromFile(filePath, 0);
            featureworkspace = (IFeatureWorkspace) workspace;
JacquesMary
yes i am very interested with  getting the workspace from an existing layer in the map , could you get it ?
LaurenPeckman
New Contributor III
Was this question ever fully answered, perhaps someplace else?
