Accessing current workspace using an ArcObjects add-in for ArcMap
9971
6
07-31-2011 12:02 PM
PaulLivingstone
I am trying to create a point feature in ArcObjects for an ArcMap add-in in c#. To do this I need to get the feature class. To get the feature class I need to know the current workspace.
How do I find the current workspace opened from ArcMap from within the dockable window c# code?
Any help would be appreciated.
Thanks
Paul
RichardWatson
Application
MxDocument
FocusMap
Layers - IFeatureLayer
FeatureClass - IFeatureClass
IDataset
Workspace
If you search the samples, I suspect that you will find the code.
PaulLivingstone
Thanks for the quick response Richard.
To help anyone else that is looking, the current workspace can be found via:
   IWorkspace ws = ((IDataset)ArcMap.Document.ActiveView.FocusMap.Layer[0]).Workspace;
OliverBurdekin
Looks good.  Any ideas how to rewrite that for Java?
LeoDonahue
Here is a sample for opening a shapefile.  Or did you want to get the workspace from an existing layer in the map?
        IWorkspace workspace;
        IWorkspaceFactory workspacefactory;
        IFeatureWorkspace featureworkspace;
            workspacefactory = new ShapefileWorkspaceFactory();
            workspace = workspacefactory.openFromFile(filePath, 0);
            featureworkspace = (IFeatureWorkspace) workspace;
JacquesMary
yes i am very interested with  getting the workspace from an existing layer in the map , could you get it ?
LaurenPeckman
Was this question ever fully answered, perhaps someplace else?
