zoom to layer does not show all layers
2880
04-14-2022 08:56 AM
RickCheney
I made a test map with ArcMap 10.8.2   I added two layers.  When I select one of the layers in the Table of Contents, right-click and Zoom to Layer, that layer appears.  When I select the other layer, the previous layer disappears and the newly selected layer appears.  Any idea why I cannot see both layers at the same time?
======= Layer 1 below ==========
Data Type: Shapefile Feature Class
Shapefile: E:\map\GPS (new map for GPS)\shapefiles and tif files\CLIPPED FILES FOR NORTH_Zone_15N\CLIPPED FILES FOR NORTH_OHN_WATERBODY.shp
Geometry Type: Polygon
Coordinates have Z values: No
Coordinates have measures: No
Projected Coordinate System: NAD_1983_UTM_Zone_15N
Projection: Transverse_Mercator
False_Easting: 500000.00000000
False_Northing: 0.00000000
Central_Meridian: -93.00000000
Scale_Factor: 0.99960000
Latitude_Of_Origin: 0.00000000
Linear Unit: Meter
Geographic Coordinate System: GCS_North_American_1983
Datum: D_North_American_1983
Prime Meridian: Greenwich
Angular Unit: Degree
======= Layer 2 below ==========
Data Type: File Geodatabase Feature Class
Database: C:\Users\PCs for People\Documents\ArcGIS\Default.gdb
Feature Class: Q_Campsites_Jan2022_Zone15
Feature Type: Simple
Geometry Type: Point
Coordinates have Z values: Yes
Coordinates have measures: Yes
Linear Unit: Meter
Tags (1)
RickCheney
THANK YOU DAN!!!   I was trying to examine the coordinates for each layer and I noticed that the scale was messed up for one of the layers.  It would only display at super closeup scale.  So I figured the data was bad.  I replaced the data and now it's working fine.
DanPatterson
MVP Esteemed Contributor
There is a good chance that one of them has an incorrect definition.
Try removing one of those at a time and zooming, or add each one to their own map and examine the coordinates on screen
... sort of retired...
RickCheney
DanPatterson
You are welcome I guess
