arcmap 10.2 spatial join wrong result
683
04-15-2022 04:01 AM
yhlyue
I run spatial join tool, when add Field map, i get wrong result. With the same input field, i get different content
I create two new field for field map, the field map like below:
nodeid "nodeid" true true false 13 Text 0 0 ,First,#,join_feature,ID,-1,-1;
ID_1 "ID_1" true true false 13 Text 0 0 ,First,#,join_feature,ID,-1,-1
In result file, nodeid contains the target.ID, not the join_feature.ID, but, ID_1 contains the join_feature.ID.
Is this a BUG??
