Working with a copied Geodatabase.
1337
12-15-2021 07:48 PM
DavidTilley
I received a copy of a counties Geodatabase. Each thing I have tried has not worked and I get this beside of all layers.
There is an .mxd file. I am able to simply open the mxd from the disk I received, but all layers show the error
Here are the folders under the main folder.
Can someone walk me through what I need to do, or direct me what I need to read. I have searched but apparently am not using the right terms to find anything relative.
DanPatterson
MVP Esteemed Contributor
I move your post to "ArcMap Questions"
Repairing broken data links—ArcMap | Documentation (arcgis.com)
is what you are looking for.  There is a disconnect between where the *.mxd thinks the data are located and where it actually is.  Usually, if you fix one  broken link others become corrected, otherwise you have to continue until the red ! marks go away
... sort of retired...
DavidTilley
Thanks so much for that. I should have considered that. I will be able to read on this and learn from it. I will reply back. Traveling over the next day
