Unable to move or rotate line features. The coordinates or measures are out of bounds.
3088
05-17-2018 10:10 AM
AlexSainz
I am unable to rotate features in a line feature class during an edit session. Lines exported from CAD (.dwg) to FGDB feature class. Projected coordinate system added to line feature class: NAD_1983_StatePlane_California_VI_FIPS_0406_Feet
The error message from the Rotate tool says: "The feature(s) could not be rotated. The coordinates or measures are out of bounds."
As an alternative, I attempted to move the line features to an area with existing features. The same error occurred for the move/edit tool in ArcMap. "The features could not be moved. The coordinates or measures are out of bounds."
Screenshots attached for both errors.
MelitaKennedy
Esri Notable Contributor
I'm not clear on your workflow. You might want to try using the spatial adjustment tool, or the georeferencing tool on the oriiginal CAD data if you need to move CAD data in a "local" coordinate system to a projected coordinate system like a state plane zone.
Every layer gets a spatial reference. A spatial reference has a coordinate system (like state plane or just geographic/lat-lon) plus some storage and processing values. Out of bounds errors happen when the data is outside or getting moved outside the xy domain / extent of its spatial reference.
Melita
