Unable to load ArcGIS 7.1 - missing VCOMP140.DLL
4527
01-21-2020 09:52 AM
JohnTullis1
I have recently upgraded from 10.5 to 10.7.1. The installation process went fine. However when I try to load ArcMap, or ArcCatalog, or ArcScene, I get the following error:
error vcomp140.dll
"The code execution cannot proceed because VCOMP140.DLL was not found"
I did a fresh uninstall, restart, and reinstall, and the same problem persists.
I searched my harddrive for all other instances of vcomp140.dll and this is what I found:
What's gone wrong, and how can I put it right?
Thanks!
Tags (1)
by Anonymous User
Not applicable
Hi JT,
This is a Microsoft .dll but I don't see a sysWOW64 entry in your screenshot and I think it needs to be there as well:
I am not sure why the file sizes vary however. Also, in terms of getting it into that folder, I suppose you could try copying one but it is usually in the C ++ Redistributable so I would just exercise caution with files in system folders so maybe try following this answer from Msoft: Missing VCOMP140.DLL - Microsoft Community
asenshaw
I am facing same problem, i see following error message when i open the program/software. i have installed it 3-4 times , i have the latest.net framework and also almost all required C++ redistribute able versions i also have the visual studio installed. still same problem.
asenshaw
after the effort many hours i have figured it out.
Minimum System requirements
ArcMap 10.7
Other versions
Visual Studio C++ 2017 Redistributable Requirement
.NET Support
Your computer must meet these minimum system requirements to install ArcGIS Desktop. For additional and updated requirements, see the System requirements page.
ArcGIS Desktop requires "Microsoft Visual C++ 2017 Redistributable (x86) Update 5". If the Visual C++ 2017 Redistributable is not already installed, running setup.exe will install it before setup.msi is launched. Setup.msi will not install if Microsoft Visual C++ 2017 Redistributable (x86) Update 5 is not already installed.
.NET Support
ArcGIS Desktop requires "Microsoft .NET Framework Version 4.5". If .NET Framework 4.5 is not detected on your machine, the ArcGIS Desktop setup will not proceed.
I had many other versions but not exactly the C++ 2017 that is why it did not work and also i have installed .net core and runtime both al together.
  1. https://support.microsoft.com/en-us/topic/the-latest-supported-visual-c-downloads-2647da03-1eea-4433...
  2. https://dotnet.microsoft.com/download/dotnet/5.0
please follow the links. thank you
Regards
