trouble clipping raster
1166
10-07-2019 03:38 PM
MiguelVigil
I am clipping a raster from a living atlas service. I am using different polygons to clip. I initially tried using the polygons all in one layer to clip. The tool took forever to run and never completed. I set each polygon to its own layer and began processing the clip with the individual polygons. I was successful until I began processing the largest polygon. I keep trying to run the clip(raster) which I used on the other polygons. The tool runs forever and I usually have to stop the process so I may carry out other actions. The other clips took about 5-20 to complete. Is it possible the polygon is too large for the tool to process? I would appreciate any help!
Miguel
DanPatterson_Retired
Did you try to clip using a rectangle, then do the final clip on the resultant, on your local machine with the polygon that you actually wanted to use.  Local will be faster than service I suspect.
