Total area covered by tracking
1919
03-26-2021 03:45 AM
JustineGüldenpfennig
Hello!
I'm very new to ArcGIS and I have a problem to find the right approach to my question:
I want to investigate the actual size of driven hunts. I have kmz files of tracked hunting dogs and beaters (see picture), and want to know the size of the area they covered. Is there a way to do that using ArcMap?
I tried merging the polylines (the tracks) and generate a new polygon feature, but it does not work correctly. Or should I simply "draw" a free-hand polygon?
Thank you!
JayantaPoddar
You could use Minimum Bounding Geometry with "Convex Hull" as the geometry type.
I used it on a river network.
Result for original streams
Result with Merged/Dissolved Streams
Think Location
JayantaPoddar
Think Location
That looks nice, and seems to work just fine for me. Thank you!
