The Arcmap 10.8.1 has stopped working
7497
6
04-28-2021 12:08 AM
Labels (2)
MuazMohamed
The Arcmap and arccatalog has stopped working every time I try to open a geodatabase , every time I create new geodatabase it work for some time then the same error appears
I used file geodatabase and other time I used Sql connection it works for some time then error come again.
The Arcgis Pro do the same error
DanPatterson
DanPatterson
Let us know if it worked
... sort of retired...
MuazMohamed
Stile stopped working every time I try to open a geodatabase
the old geodatabase (10.5) work fine put after edit and save in (10.8.1) and close the geodatabase and try to use again the error appear
MuazMohamed
attached debug report
DanPatterson
You should really contact Technical Support to get this resolved.  They have far more resources at their disposal
ErkiboMechale
i need clear and precise answer for this problem
